Astro
I have ar 230 ho with water flow issues, Temps in the front Cylinder 1 of port engine are up to 185 but much cooler everywhere else ( 90-140). I suspect the water jackets are plugged, especially near cylinder 1 bec its the furthest from the inlet and gets less water pressure. Got stuck on shore end of last season, and im sure i sucked sand into jet pumps.
Im going to try the closed loop flush this weekend but if it doesnt work i wondered if anyone has tried
manually cleaning out the water jackets by removing the water inlet tubes on the side of manifold and poking a long thin stiff flexible wire in the exhaust manifold water inlet tubes < see pic?
