Cleat nut size?
Impelled
Columbus, Ohio
Okay, I’m confused....
The service manual says the nuts on my cleats are 5/16 X 18. I know the outside size is 1 1/4.
When doing a search I’m reading the inside diameter is 7/8 X 18 according to several threads.
Which is it? 5/16 doesn’t even seem close for the strength needed on a cleat. Even the manual gives the lock washer & washer as a 5/16....
I’m missing a nut & washers off a rear cleat and need to get a replacement.
TIA-
