gthorson
- Syracuse, Utah
- 252XE
2021 252XE. Connext clock starts our fine but reads "0" or "0:00" after a while. Full battery disconnect and reboot gets it working again but I don't want it to leave it be as it might be a symptom of a larger issue. The rest of the system and screen work just fine for now. The system has had several glitches including this in the past but after a warranty service the dealer said a grounding fix solved the problem. Because the other glitches were random (clock, push button start, F/N/R stuck, steering error) and didn't seem related other than electrically, a grounding fix made sense. Has anyone had similar clock issues? what was the fix?
