Crack at rudder attachment upper bolt
Chip F.
Schuylkill Haven, PA
Found this crack today while doing my check out in the driveway before going out . Something else to take a close look at when you get the opportunity.
Now I found another crack while spraying the pump units down with CRC 6-56 .this time it's on the starboard side pump upper left bolt -another punch list item....
Those look like spider cracks in the gel coat. They can be fixed but will likely come back. Since they are below the water line I would consider covering them with a little bit of silicone.
