Welcome to Jetboaters.net!
Does anyone know if a 195 stock depth gauge will work on a 2012 SX190? I've tried searching to see if it would work or a "how to" to get it done. Thanks.
There isn't really a stock gauge per say, its incorporated in with the instrument tachometer speedometer multi gauge that you have. However, the SX190 does not have the transducer installed. I believe that the AR190 does have it. I choose to just get a Garmin http://g.factoryoutletstore.com/det...ducer.html?category_id=0&catalogitemid=391340 ( for saltwater coast line). If you need for freshwater order this one: http://g.factoryoutletstore.com/details/257072/garmin-echomap-chirp-43dv-with-transducer.html . It works fantastic great, GPS, fishfinder and depth guage all in one. Had it installed for 150 bucks and they made minimal holes in the boat installing it. Plus you can remove the unit when storing your boat. Looks good too I will post a pic later.....
