diagnostic connector location on a 2014 212ss??
olouieo
SS
Hello, can someone help me out? Where is the the diagnostic connector(s) on 2014 212ss? I got the check engine light on the starboard engine. I bought the YDS pro2. I scrolled and no codes on the info screen. Thank you for your time
Scottie
Helena, Alabama
Behind your dash. Labeled diagp and diags, for each engine. You must unplug the tachs before YDS will connect.
101581
olouieo
SS
Thanks for the fast response Scottie. one more question, Do you happen to know what is easier to remove the dash or go through the front seat? Once again thanks
Scottie
Helena, Alabama
I would suggest going through the front seat back into the helm. The diag ports branch off of the tach connections, so if you don't see them just hanging, you can trace the wires back from the tachs.
