brian86992
- Houston, TX
- FSH Sport
I was hellbent on getting a center console and surfing off it so here I am. No tower for a board rack and the T top tube diameter is too small to attach a rack. Not to mention, I walk on the gunnel all the time so I'd constantly be smacking my head. Surprisingly few threads online about no-tower wakeboard racks so I'll share mine.
Yamaha will be coming out with a product in the next months to help a bit which stores a board on the T top: Surf Carry Pocket. I had been using bungees to strap the surfboard to the T top but it's not very secure and a pain.
There's also a company called Manta Racks that has a product similar to what I built but at $450. I thought that was pretty steep. Manta Racks B3
![1601494356390.png](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/134/134645-0a1b8d22fea777936b1b7fa46f8de1a3.jpg)
Going the DIY route, here's my final product. Total cost under $140 and I could build one again in 30 minutes.
![IMG_3645 (1).jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/134/134655-da9466417103c6a5b78018cb577b0e5f.jpg)
Parts:
$130 Three board rack, adjustable tilt with inserts for multiple tubing sizes
$2 1.5" SCH 40 PVC
1.5" PVC internal connector Any component to slide in the 1.5" PVC will work but it is very difficult to find parts that insert in PVC pipe.
Build:
![1601495510512.png](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/134/134650-67171139a71830596eedce1dae701461.jpg)
![IMG_3697.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/134/134651-b9869ea3fe65e7be0820a0098ee91e88.jpg)
![IMG_3636.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/134/134652-04bd068a580ecd8be2dc23f082101c05.jpg)
![IMG_3640.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/134/134653-85e2f5786b7a840533c7d32b4f502dbd.jpg)
With three board on the rack, there is a fair amount of torque to rotate the pipe which should be no issue for the rod holder. The cantilevered weight does make me a bit worried about the rod holder's fiberglass attachment. I will probably pull the rod holder and put captive nuts on the back side so it's not just screws holding in fiberglass but they have a nut to bite on. I might also try to find a way to fill the area around the rod holder with foam so after it expands it will support the force of the rod holder. While the boat is trailered I can bounce the weight of the boards (more than they would while on the water) and there is only minor deflection of the gunnel so I don't expect that to be an issue.
First weekend out with the rack was a game changer. I wasn't moaning and moving people around the boat every time we wanted to swap a board. Crossing back over my surf wake was no issue for the rack which has surprisingly little movement because this location is more or less the pivot point of the boat.
Parts:
$2 1.5" SCH 40 PVC
Build:
- Decide which rod holder to use. I used the stern starboard holder. Keeping the rack close to the rear of the boat will minimize shock in rough water and it's also out of the way for my port side surfing.
- Pull out the rubber insert in the rod holder. On the FSH, it's a perfect 2" (or just shy of) ID which fits the 1.5" PVC (1.90 OD) like a glove.
- Install internal coupling in PVC with generous glue. This creates double wall thickness for your notch that will prevent the rack from turning.
- Cut the coupling next to the shoulder.
- Notch the PVC to accommodate the rod holder support bar. Do not be sloppy with this. Make the cut at least perfectly perpendicular or even better undercut it at an angle (opposite on either side) so as the tube tries to rotate it will hold itself in the holder instead of lifting out and spinning. With three boards on the 15deg rod holder, it's a fair amount of torque.
- Install rack to PVC tube at your desired height. I put mine with just a little clearance to the gunnel. I put strips of the included rubber insert between each layer of spacers to prevent rotation.
- Cut excess PVC above the rack clamp.
- Reinforce rod holder?
