Ronnie
- SF Bay Area
- Limited S
Just thought I'd revive and old topic. I bought another wash down pump kit yesterday. It's time to refurbish my electric water gun.
I built (more like pieced together) my first one 3 or 4 years ago. Primarily to use when we go slow rafting (Class .5 at most) down the American River (the alternatives being to go unarmed, with a bucket or a traditional tube style water gun) but have also found it useful to pump out flooded compartments (like leaky waverunners and flood rafts) and as a portable washing station when fishing.
So its a very simple contraption really, the pump is mounted along with a battery in a covered battery box. When not in use the intake and output hoses are stored, for the most part, in the battery box. You use the water you are boating/fishing in so there is never a shortage of it and its easy to use, just squeeze the trigger (I bet my hand would give out before the battery does).
Lessons learned/re-learned: 1. The bigger the pump/gpm the costlier it will be but it will be more powerful as well. 2. The pump will rust/freeze up quickly when used in this way. It can operate dry but after putting them away for the season I've noticed that they generally don't perform as well the following season or they don't work at all. This is why I purchased the 2 year exchange policy this (the 3rd or 4th) time around. I may start to 'winterize' this by running cooking oil through it at the end of the season. 3. If possible by a wash down kit, otherwise you get nickeled and dimed and/or will have to make more trips back to the store. 4. Use a sealed battery for what should be obvious reasons. 5. A single battery is enough, the one pictured has two batteries (I had a spare when one of my two water guns broke down) which turned out to be heavy and unneeded.
Cost: Well I think this is very "cool" but it isn't "cheap", its seems very rare that those two words go together in a single sentence anyway. The battery box is around $10. The this kit pictured was $160ish including tax and a 2 year warranty. The battery is another $50 to $100 depending on what type and brand you get, its a 12V PWC battery. So all told this one will cost between $220 and $270 (assuming I need a new battery).
Future changes: I saved an old rollway cooler from last summer that I plan to install the gun components in along with exterior mounted speakers and an amp. This way I can roll it around instead of carry it around and I'll have a place to put my mp3 player/radio tuner as well as project sound from it. I guess its time for me to look for the speakers I saved for the task (and an amp). This could be a $400 thing when I'm done.
Overkill? Oh Yeah but I'm looking forward to challenge of building as well as the fun of using it.
Any questions?
