rocknracing
- Winfield, MO
- Limited S
Have a Elevate Turbo Ballast pump that was only used for one boating season. Sells for 109.00 at Wakemakers and asking $90.00. Below is the details of the pump.
The Elevate Turbo Ballast Pump is designed to fill Fly High Fat Sacs faster with a hose that will not kink. The true 1-1/8" hose is reinforced to eliminate kinking when hanging over the side of the boat. Anyone that's used a Fly High Tsunami Pump can attest to the way their clear hose collapses during use especially when it is hot outside. As the diameter of the hose is restricted the flow of water is slowed and it takes more time to fill and drain ballast bags. Elevate has fixed this issue, which means you get the true rated capacity of the pump.
Elevate designed the pump to be compatible with the Fly High Quick Connect Fitting system that come standard on most Pro X Series Ballast Bags and Fat Sacs. The pump has a new and improved design and it is comparable in price to the Fly High Tsunami Pump. Time is money, and the Elevate Tsunami Pump will help you spend more time behind the boat wakesurfing and wakeboarding and less time trying to un-kink your hose.
Hose Length: 10 feet
Wire Length: 12 feet
