Engine shutting down
RJM123060
2015 AR210 Twin engine. My #1 (left) engine shuts down anytime I have it in idle. The idle is set at about 1500 rpm, same as the #2 (Right), but the #2 runs smooth and almost never shuts down. When running under power they both run fairly normal, but the #1 seems to run at a slightly higher RPM with both levers set the same. Is there an adjustment I can make to keep the engines running at idle?
