dan_hoog
- Vero Beach, FL
- Limited S
Hello,
I am a first time boat owner, with about 10 hours prior experience. My boat is on a lift at our community's marina, so my setup/prep/departure and cleanup procedures are adjusted accordingly. We do have several fresh water spigots available as well as shore power, that I leave connected to a smart dual battery charger. I use plastic quick connects on the hoses and accessories and a flush connector that itself is connected to a short hose. Still working to leave hoses hanging in the most convenient positions.
I am being very careful with flush procedures, no need for towing yet, etc. However, I wanted to get a feel for the risks during various procedures.
Flushing: I almost opened the rear seat platform to remove plugs while flushing yesterday (didn't though, as I realized it would kill the engines). Had that happened, I would hopefully have gone immediately to the flush port and turned water flow off. Would that likely have been too late? Could I ruin an engine by accidentally opening a hatch, moving a lanyard, bumping a key? I plan to be very diligent, but I'd like to have a sense of just how much risk there is, so I can ensure I have adequate procedures.
Cleaning: I spray the boat with a sprayer at the end of an extending pole, first with salt-away, and then with fresh water to rinse after each trip. The inside and outside hull areas are no issue, and actually seem to clean up quite nicely. I also spray under the rear seat around the transom area, trying to get salt residue off the mechanical items. While I'm not deliberately spraying water into anything, the underside gets randomly sprayed from many directions. Is there an engine risk in this cleaning procedure? Any special precautions or am I worrying too much.
Towing: I hope not, but some day I may need to be towed. At first, I thought I'd install (or have installed) tow valves. Now, since that seems like an unlikely event, I'll probably just purchase two of the cooling line clamps I saw in another thread (need to find it again). I haven't looked, but hope I can have positive confirmation on the particular hoses and plan to attach two "CLAMP HERE" stickers, so I can quickly find the location should I need it. I'd keep the clamps in my CG/emergency/First Aid box stored under the helm.
So far, the first few trips have been great (the first was 2+ hours from dealer). Loving the new toy....
Thanks in advance for your thoughts,
Dan
Dan
