engine wont start
doug goeckel
39531 biloxi ms
changed plugs today in both engines and now it wont start it turns over fine but well not fire--what is lanyard and location-- sr230 year 2005--any ideas--thanks doug
Beachbummer
Houston TX
Lanyard is the string you are supposed to attach to yourself and plastic clip you are to clip on the special switch near the throttle levers so the boat engines power off if you are thrown off the boat. Also known as kill switch or dead man switch.
Beachbummer
Houston TX
Any chance you reconnected the coils out of order? Each one has a dedicated electrical connector position, they are not interchangeable.
mattbaker
Maybe you exchanged the locations of the plugs! Try rechanging it and see if it works!
doug goeckel
39531 biloxi ms
[/QUOTEwould this stop both engines from firing
Beachbummer
Houston TX
If you got it wrong on both sides perhaps. It would be rare. You don't need to remove much, just recheck the wires are not crossed to the harness and that the wires are connected in order to each of the coils.
More likely with neither one firing is the lanyard, but seeing you recently only touched the coils it's worth a check in that area
doug goeckel
39531 biloxi ms
the coil is were the sleeve that goes on top of spark plug and the clip attaches to fire plug
doug goeckel
39531 biloxi ms
w
would engines turn over but not start
Beachbummer
Houston TX
Hope these help
doug goeckel
39531 biloxi ms
thanks--those pic's are really helpful--went back to boat and it was the lanyard and some of clips were not on all the way-- question--if you get coils in different holes than they came out of well that make a problem?
the lanyard was disconnected ---thanks--well it cause a promblem if coils are in different cyl. then you took them out of
Beachbummer
Houston TX
No problem if the coil is in a different hole, as long as the connection matches the one intended for the cylinder. All the coils are identical, but need to be matched to the right connector for the position they are on.
If it started,, all is well.
doug goeckel
39531 biloxi ms
thanks for all your imput
