djtech2k
- WV
- SX
So I have been putting together my list of things to get done to my boat before its warm enough to get it in the water. I have a 2012 SX210. I have been looking for referrals around the closest lake to me and then reaching out to those people with the things I want done. I am asking for their availability and any kind of ballpark on costs. I will post my list and I'd like to see if you guys think it looks reasonable or what not.
- Cavitation on Port Motor: Based on my threads here, it seems like I have some cavitation on 1 motor. Its not horrible but its like a slipping clutch. I'd like to get it looked at and fixed. I was told here that it may be the channel leading into the impeller not being smooth. Mine is not smooth. I have no idea what else it could be.
- Throttle: My throttle seems to have some play to where when moving forward, it does nothing and then suddenly starts to go. I dont know if this is normal or not, but I was guessing that it could use tuned. I also have the thing where when I open it up to full, it creeks back down. So I think I need a throttle adjustment.
- CobraJet Install
- Buffing/Polishing: I have some oxidation on top and some discoloration on part of the hull. I'd like to get it smoothed out and waxed for boat season.
That is what I asked about. Here is the response info:
- Would need to look at damage to prop and wearring. Wearring is about $330 and prop is about $300.
- Removing and resealing the pump is $450.
- Installing CobraJet is $300
- Buffing is $25/foot
Ok, so I do not know much about wearrings, other than hearing about them. I assume he means that the wearring and/or prop could be causing the cavitation. And I understand that he would need to see it to know if it needs them or not. What I do not know is about the pump remove/reseal. Is that a separate possible cause or is that needed when you do the wearring or prop?
I realize that this guy is just giving me possible estimate stuff, which I appreciate since he is 2 hours from my boat. This is not about getting a commitment from him but about me trying to estimate possible costs. I was definitely not expecting this much for some of this stuff, but maybe this is normal and I had bad expectations. Like the cobrajet install at $300 seemed high, but again I wouldn't know.
- CobraJet Install
