Every time i step on my swim platform hatch my starboard stalls out ...
yam240sx
Im guessing and hoping this is a bad safety pressure switch .. i was thinking of 4200 it closed down but my luck one of my kids will start and engine while im cleaning out my port one day and lose a paw .. any ideas for a fix ? thanks
Sounds like it’s the safety switch like you said. If there isn’t any adjustment in the mount you can glue a nickel (or any kind of shim) on the bottom of the hatch where it hits the switch.
Sounds like it’s the safety switch like you said. If there isn’t any adjustment in the mount you can glue a nickel (or any kind of shim) on the hatch where it hits the switch.
excellent idea ... Thanks ... but if i needed to replace the switch i cant find it in the parts diagram ... would you happen to know if its easy to replace or get the part ? Thanks
I know by pass is an option but not a good idea
*btw the preferred hack to bypass safety switches is to cut the wires and twist them together. Tape/wire nuts optional.
Looks like part 22 in this diagram.
But it sounds like yours just isn’t making good contact with the hatch.
Wow its listed over $150 .. and who even knows if its easy to get ahold of ... id rather spend $150 on gas while its still under 4$ lol
Did exactly this and it worked like a charm ! THANK YOU ! =)
I’m with sunbyrned on this. The switches are adjustable. Sounds like that’s all you need to do raise it up a little to make solid contact.
