Expandable hull breach plugs
MOA_Chaser
Chicora, PA
Has anyone used these before? It looks like a better solution than having various wooden plugs on board. I guess they're expandable like the compressible ear plugs.
http://www.forespar.com/Truplug/
Those are cool. Nice find....now what do I do with all these wooden bungs I've got scattered around the garage? Hmmmm, there will be a large campfire at some point this weekend...Problem Solved!
I did some more research, and someone had a good point... what would be all that different than keeping a few Nerf footballs on board? They can be compressed and stuffed into holes in the hull as well. Could cut off pieces to fit as well.
I use Captain Ahab's peg leg repair kit, or for the smaller holes, the "Pinocchio" small kit repair. You just break a piece off a leg or nose to fit, and you are done. :)
I bought two for our trip to Grand Bahama Island last year. However, I did not need to use them :).
In my experience a hull breach caused by impact isn't a simple hole that can be filled with some sort of plug. I guess under the right circumstances it might come in handy, but do you swim under the boat and apply?
I agree, I'd assume impact hull breaches aren't going to be stopped by these plugs. However, it seems like a great backup for those with the "If it ain't broke, don't fix it" mentality of the original scuppers.
Theses plugs can and WILL help in a hull breach. They may not completely stop water ingestion and are not really designed as such. It's more to dramatically reduce the volume of water entering. Hopefully this will allow your bilge pump(s) to maintain
I hit a stump and the breach manifested itself as very large cracks. There was no way to "stuff" something in there, and you would have to dive under the boat to do it even if you could. I can see a "puncture" that is somewhat round or oval, especially on the sides. The bottom of the hull is very thick and the force required to breach the bottom will most likely not leave a void to be filled but rather damage spread out as cracks..
How am I to stuff something in here in the water?
Of course in your situation..it would not work. Unless, you cut out some of the glass that's damaged THEN stuff plug.
