djtech2k
- WV
- SX
After a lot of planning, I finally got to winterizing my boat today. I followed all the stuff I have read here and answers I got to my questions. I thought I would post back my experience.
I decided to change the oil in both engines but not change the plugs until spring. I did not want to get them dirty with the fog or let them sit all winter. SoI’m the spring I will change them.
The oil change was not too bad. I did the port engine first. I used the pet pads to not make a mess. I used the EWK oil extractor that I bought. I ran the engine for about 10mins with water running into the fish port. Pumping the oil out was easy and simple. I got about 2 Liters out of that motor. I put one pad below the oil filter but it is kind of hard to get to. Far more oil came out when I removed the filter so it went on the pad, on the boat, and drained under the motor to the middle of the hull/bilge area. It was a mess. I wiped it up the best I could. I put the new filter on and out in 3 quarts of oil. I ran the motor for a couple mins with water and checked the oil. I did make a mistake and left the water on after I shutoff the engine for about 30-60 seconds so after I turned the water off, I ran the motor for a few seconds to hopefully push out any water.
The starboard engine was easier because it’s easier to get to and it was my second time. About 1.5-1.7 liters came out of this engine. I put in 3 quarts and did the rest the same. All good.
I also fogged the engines. On port engine I pulled out the air filter, blew it out with air, pulled the intake hose and sprayed the fog in in spurts with the engine running with water running. It only took a few squirts before it shutoff. It maybe took like 6-8 squirts. Once it shut off. I ran the motor for a few seconds without water to blowout water. After it ran, I shot some air into the flush out valve to also flush out water.
I did the exact same for the starboard engine. It took several more squirts of the fog before it shut off but everything else was the same.
I did a quick wash on the outside but it got cold so I couldn’t do an in depth wash. I was planning to do a deep clean, buff, and wax the boat, including the hull, but I think I am going to wait until spring to do that. I’m short on time and it’s a much bigger job than I expected with doing the hull. There’s some discoloration on it that I thought was dust/dirt but it’s doesn’t wash off.
I plan to remove the batteries before I park it for the winter. I also put in the fuel stabilizer and will top off the fuel tank on the way to park it.
Did I miss anything? Hope this helps any new person walking the same path. The FAQ was my main source of instruction, along with my other threads on here.
