Flushing Yamaha Jet Boat
giff
Flushing Yamaha SX190, Anyone ever connect a light duty pressure washer to a Yamaha flush port to give the engine a stronger flushing?
You’d be better off installing tow/flush valves. Too much pressure and you run the risk of blowing gaskets.
Understood and thanks. I actually bought a valve to install to close off the seawater intake line because I flush while floating in my slip. I just ended up clamping off the rubber intake hose as I had no room to install the valve.
@giff I would not pressurize the cooling system in any way. The cylinders and water passageways are very close to one another. I think it is possible to force cooling water into the cylinders. Even tow valves increase the pressure on the cooling system. Looking at a head gasket will show how close the water passageways are to the cylinders.
