Fogging Oil Air Intake
I have the same boat and perform the same process. Just hold onto that spray tube!!
Yeah, that would be a bad end to end of season winterization.
I hate when that happens......Murphy law at it's finest
Anyone see Will's new winterization video..https://youtu.be/awLqU2TwPow
I gave up taking off the air filters (too much of a hassle) and spraying the intake, I just spray the cylinders. This blue adapter is intriguing..Looks like you just tap into the intake with a hose fitting with a fitting on the end for the fogging spray tube. Problem is if you spay too much it will head back to the air filter...Anyone have one on your engine?
