SOLD FS: 2001 Yamaha LS2000 $7950, Downingtown PA
4x15mph
Downingtown, PA
I am putting my boat up for sale in-season. Price is firm and you will see my boat listed other places for slightly higher.
2001 Yamaha, LS2000. 270 HP, Twin 2-Stroke Engines, 19'6", 8' wide. 7 Passenger (1300 Lbs) , Aerial Ascent 2.0 Wake Tower, and very fun, fast, sport boat! This is easily towable my many mid-size SUVs at 2100 Lbs (dry weight excluding the trailer). I have the titles for both the boat and trailer. Boat is registered and I will continue to use it up through selling it.
This boat was well maintained and many after market upgrade/maintenance items have been added since I took ownership 5 seasons agoIMG_1421.jpg. I have priced this to reflect what I expect and I have done so looking for a quick, in-season sale. Cash or Cashier's check please.
Key improvements include:
• Wake tower, board rack, and mirror -- In addition to improved boarding, great looks, and improved viewing (rearview mirror), this adds more space to the boat by getting the ski equipment outside of the boat. Over $1K not including installation.
• Like new 2012, galvanized trailer with LED lights. This is a $1500+ galvanized trailer that includes a spare tire carrier and spare tire.
• All new aluminum rims and tires in June 2019 ($350)
• Hydro Turf flooring -- no carpet and no slippery deck. This custom, black flooring requires a quick rinse following any outing.
• Keel protector -- after market keel protector protects the bottom and I replaced this with a new black version August 2018 since the prior white one was yellowing.
• Entire jet pumps on both sides have been replaced to include liners (replaceable), new ducts, and new impellers. This was done to restore to "as new" condition, similar to putting a new blade on a razor.
• Sierra Gas/Water Filters (x2) -- removes water from the gas in addition to filtering. Water is a problem that is increased with the Ethanol that is found in most gas.
• GroupK Air/Fuel Separator Kit -- removes air from the fuel delivery, which was a problem with these boats given their quick turning and the fuel delivery system. Provides pressurized fuel, which improves initial, 2-stroke startup. Must have
• Oil injection -- You will see many boats have switched to pre-mix for a reason (i.e. blown engine). This boat has after market, oil line kit that preserves the benefits of the oil injection, minimizes smoking found in pre-mix setups, and eliminates the need to pre mix oil/gas.
• All new gauges 2018 -- You will find many of these boats with non-working gauges (fuel, tachs, speedo)
• New top end rebuild on Starboard engine provided by fullboreonline.com. Premium pistons, rings, et.
• Sony AM/FM/CD/MP3 (New) with Bluetooth and 4 speakers. Remote control on drivers side.
• Graphics -- other Yamaha 212 style graphics were added to the boat.
• 2018 non OEM cover
• Reupholstered rear seat cushions and rear sun deck
• Stainless steel cup holders
• Stainless steel scupper valve (to replace plastic scupper that tend to crack/leak)
Other miscellaneous items ($) that will be included:
4 standard, life preservers
Tow rope for skiing
Bumpers for docking
Fire Extinguisher
First Aid Kit
Flush Hose for engine
Anchor w/ Line
Spare keys
Owners Manual
