Garmin transducer install location AR240
Cbaldwin23
Hello I was trying to install my transducer on my 2013 AR240 and was trying to figure out the best location
I installed mine in the same spot the OE depth finder was located. Used the same thru-hull fitting and just sealed around the cable and screws.
I don’t think I have an oe depth finder I looked
do you have any pics?
Nope. Works just fine.
Mounted mine to the flat part of the ride plate with a piece of starboard and a flush mount bracket
@Neutron
How does the side imaging work in that location? Does it see to the right amd past the keel?
I have a 2010 ar240 with no keel edge. And trying to figure out how to mount a tranducer
@Neutron
Only a very small percentage is blocked, which i can live with since i am not searching for lost ships full of gold.
My biggest concern was would it read at high speeds and it works flawless at any speed
@Neutron
You can install another transducer on the other side, each will scan that side. I had it done on my AR190 and it worked.
Doesn't bother me one bit. I dont use side scan much and when its on. I hardly look at the screen
