Gas Shock Size Cooler 06 AR210
Trevor Shipman
Charlotte, NC
Anyone know what size shock I need for the cooler in a 06 AR210 for the in floor cooler? I'm not near my boat wanted to swing into an auto store and grab a replacement.
Thanks!
My 08 212X took 30 lb force, 15" extended, 9.5" collapsed. Collapsed size isn't as important, I think you can go as low as 9". I got the ones with 10mm sockets on both ends and they work. A 9mm might fit, but not totally sure there.
No problem. That shock seems like such a minor thing, until that door drops on your foot. :confused:
I recently replaced both floor springs in my 07 AR 210. I ordered the Attwood SL33-30-5 springs from either Overton's or iboats.com.
Just providing a model number if that helps.
