vxooxv
- Harrisonburg, VA
- SX
When I bought the boat in the early spring I did notice what appeared to be a gel coat repair (which is what appears to be rubbing off). Knowing what I know sorta now a good job I probably should not have even noticed the repair as it was slightly raised. As if a coating over not smoothed in so to speak.
At any rate since I dont have a lift I don't know how far this goes back and last time I had the boat off the trailer I didn't notice anything wrong with the bunks that would cause this. So now I dont know if I have a bunk issue along with a gel coat issue. The bunks appear to be scuffing the other size too.
So- these plastic bunks??? Garbage or what am I dealing with there?
As far as the gel coat. I only have 2 more weekend trips planned. At most that's on / off the trailer twice. I know it's probably not ideal to let the fiberglass get wet. Will I trash the boat if it does?? What's my risk outside peeling off some of the older patch?? I'm trying to find a reputable place around Anna (recommendations welcomed) but these 2 last trips are the ones planned all year and there is zero chance I can get it repaired before this weekend or Labor Day so I'm torn.
