AAron21
- Kingwood Texas
- FSH Sport
2nd time on the water and not very good. Can not get over 10mph and boat sounds horrible past 6k rpm. As if impeller is contacting wear ring or some other friction. No codes, engine sounds good in Neutral and revving throttle to 6k. Removed impeller and wear ring and hopefully this is the issue. I do not notice any swelling of the wear ring but obvious signs of simpeller contact. Plan is to order new impeller and wear ring. My concern is the wear to the housing behind the wear ring. Tach shows only 29 hours, so it’s obvious previous owner did some damage on a sandbar. Should all of this be replaced? Is there a way to have both these units resurfaced to save for later? Thanks in advance, I appreciate everyone’s input. Super helpful for a first time jet boat owner
