MrMoose
- Calgary, AB, Canada
I have a 2015 AR240. When I engage no wake mode, it works as expected. When I throttle up using the throttle levers, and then throttle back to neutral, no-wake automatically turns off, and my rpm is at idle. If I am in no-wake mode and I pull the throttle levers into neutral, my rpm does not come down to idle; it remains at the no-wake rpm. I have to use the no-wake button take the rpm out of no-wake and back down to idle.
I am 90% sure that when my boat was new, pulling the throttle levers into neutral caused the no-wake to disengage.
Does your no-wake disengage when you shift into neutral?
Thanks
Thanks
