I need help, no spark
ZacB08
SeaRay
SR
So I’m not sure why I wasn’t able to enter in my info correctly but I have a 1994 Sea Ray, Sea Rayder with a Mercury 3 cylinder 2 stroke engine.
The boat ran fine when it was parked but sat for about 4 or 5 years. When I got the boat I put a new battery and starter on it and was not able to keep it running for longer than a minute or two at a time.
So I first looked at the wires and they seem just fine. I’m not getting any spark on the lower cylinder and I think the first part I should replace next is the ignition coil but I’m having trouble finding the right part.
If anyone has any info on this issue, I’d appreciate some input. Thank you!
Yes, sorry I didn’t realize I left that part out. The plugs were actually the first thing I changed when I couldn’t get it to start
We had an 1970's vintage 115 Evinrude (sp?) 2-stroke. The CDI module went bad and at low rpm only 1 cylinder would fire. At higher rpm they would all fire. The failure was in a diode that would leak down voltage at low rpm but maintained enough voltage to fire at high rpm. Search for "how to test cdi with multimeter".
Thanks for the tips! Wish me luck
