Big Daddy
- LS
I"ve been having a problem with my key switch on the port engine of my 1999 LS 2000 jet boat. When turning the key "OFF" to shut the engine down....the engine continues to run? The only way I can shut it down is to pull the lanyard cord. Now when I turn the key to "START" the motor.... I have no juice? Nothing happens. I checked the safety switches in the transom and they are fine. Could this just be an ignition key switch replacement or something else causing the problem??
