Impeller tool
mb300sd
Athens, GA
Does anyone know if the impeller shaft holder is the same for a LS2000 and AR230? I have the LS2000 tool and want to make sure it will work before I pull the pumps. Hoping to do impellers, wear rings, and pump cones all in 1 day.
I believe so. Which part number do you have?
The 230 shaft is WR007H.
Nope, I have WR004H... guess I gotta order 1.
My impeller shaft tool was a good bench vise and impeller was open end wrench with "extension" wrench.
I have the solas impellers now and can just use a wrench on thier tool with rubber mallet again, bench vise.
