Interior Cleaning Recommendations
GoodCubanito
Lewisville, Texas
Hi everybody!
What are you guys using to clean your seadek and the upholstery on your Yamaha jetboats? Trying to get it ready after a few months seating in my driveway...
Thank you!
Hi everybody!
Thank you!
I use vinyl sauce(made by boat bling)for my upholstery for cleaning. And 303 aerospace for UV protection after cleaning(also use this on my Bimini top to prevent fading) Jetboatpilot sells a seadek cleaner, or you can use simple green as well I believe
I also recommend Boat Blings products. Vinyl Sauce and Condition Sauce are great for the seats.
Here ya go
I use the boats alot. I quickly learned nothing works better than classic soap and water. I stopped wasting money on "interior cleaners". If you have stains you might need something a little stronger, but day-to-day soap and water is king.
soapy water does well on seadek, however all plastic, upholstery, rubber seals around windshield etc. need protection from UV - 303 AP is the best I know. I buy it by a gallon.
I made this mistake when first came on here. 303 is highly recommended and great for protection - but it is not a cleaner.
correct. that being said, it can "lift" some stains with repeated application and repel other.
I see boats with fired upholstery tops - so preventable.
I ordered this one, I have wanted to try it for a long time. not a cleaner and crazy expensive
I'm curious how it does, supposedly it's the cat's meow...
