I like that remote. Simple and to the point. I have something similar for my LED floodlights for my front yard.
What controller/other materials did you use? I am looking to redo my boat LEDs sometime this year.
Can you share how you hooked into the power? That looks like the easiest way to do LEDs I have seen. Thanks for sharing.
Also, did you look into a dimmer of any sort for your install?
Good thinking @geiger41 I just ordered this whole set up to use under the railing around my deck. Figured I would test it out there then move to the boat next. A lot cheaper than the deck lights you find at Lowe's!No way to snap the wire ends into the connectors, thus eliminating the soldering ?? If so Ill put some under my deck at the house
