Jetboat Slip Available
ISLANDRACING
Vendor
Baldwin NY. We have one open jetboat slip available at our marina due to a customer moving last minute. We are also a distributor for the products shown. Boat slip can be built to support up to a 30' boat up to 6000lbs
I was just looking at these today. How much do they run ? 24 ft boat.
Whoa! That hilarious! Hull damage? If not, cool!
I'd like to know about hull damage as well
I've used JetDocks extensively with propped boats. The dock will leave some residual marks that are generally from dirt and the occasional plastic mark that buffs right off. Both are really of no concern especially if you install a Keel Shield. Here, in the salt water, the biggest problem with these docks are the barnicals that grown in the area where the keel first touches the dock.... The barnicals cut and gouge the gel coat like its butter.
Exactly what @Murf'n'surf said. I used them for years, fresh water only. There is a learning curve, but I wouldn't want to use anything else.
My marina can get really low water at times - many with conventional lifts can be stuck for days - I can ALWAYS get in and out.
I'm really considering one....how about instillation ?
