cwoav8r
- Naples, Florida
So, yea, long time no sea... work has been getting in the way of my personal life for way to long, and severely interfering in my water time. Even though, every time we have had a chance to get out on the boat (read... like four times a year) I have had no issues with the boat at all until last month. (last trip was a month prior with no issues at all)
Launch the boat, make the agonizing 20 minute no wake trip, and firewall the throttles.... the right engine will only make 7k. I thought maybe it would clear up after a little warm up... but no. At cruise the throttles were split more than an inch and a half to keep them both at 7k, the right one would just not go any more. First thought was maybe the cable slipped. Opened it up, and sure enough there was a bit of slack... took it out, but with no change. Why I tried this next I don't know, but every other time I tried full throttle in reverse the right one would make 10k... As I suffered a swollen impeller housing due to corrosion on the left pump a several years ago, I thought this might be the case. At any rate, we were able to enjoy the rest of the day, and I knew when I got home I could log on here and find the answer.
Folks, when I searched for an answer here I found a ton of posts relative to my problem and the majority were about spark plugs. In those threads were doubts about whether or not the plugs could really be the problem... JUST CHANGE THE PLUGS! Next trip with new plugs in hand... 10 minute job and I immediately noticed the RPM change after starting at idle. As soon as we made it out of the zone, 10.5k on the problem engine... YES. 10k all day both sides...
And on that note, in reference to the anti-seize debate... (and I am ashamed to admit it had been a little over four years since they were changed) my Iridiums without anti-seize turned right out, no problem. Just warm up the engine before you do a plug change and it should all work out fine. Oh yea, if there was even a question about the NGK Iridium (CR9EIX) plugs in the MR1s, they last about 4.5 years... ;-)
So, just to add... the MR1s are pretty much bullet proof for those looking to invest in a boat (or jet ski) so equipped. I have never been happier, and never spent so little (with respect to engine maintenance) on my AR-230.
Oh Yea... New steering wheel for Christmas!!!
Guys, Happy "belated" New Year! I hope to get a little more active in the near future...
Cheers!
Ed
Cheers!
Ed
