mraz72
- Rochester, NY
- 242X E-Series
On the southern shore of lake ontario things are a mess, we are 2-4' above normal for a prolonged period of time and I can say the lake environment wasn't built for 4' rises in sea levels.
Anyway, there is a lot of debris in the water, so I suspect that is what I am experiencing, i just want to make sure that I have my terms correct.
The first outing (first ever for the boat) the boat is really awesome, like others have said the throttles are silky smooth. The engines are a little loud but MUCH better than my 2015 sx 192. Anyway, after a while I noticed that when I increased throttle, I get a lot of vibration and the boat was slower than normal. I suspect I sucked up a twig or whatever or all of the floating debris.
I tried to go in reverse and forwards a few times, didn't really change anything. Then I just turned around and drove the boat back to the dock (hour drive)
during the drive, something happened and the throttle went back ti being silky smooth. I suspect the boat spit out whatever what digested?
Second outing, same thing only this time I opened the plugs and felt around. I found a plastic bottle top and small twig just floating in the hole. I didn't feel anything around the impeller, as best as I can feel around on the water.
the entire drive back, I had the same throttle conditions. The boat moves BUT more vibration and not as fast.
I may pull the pumps this week just to look in there and make sure something isn't lodged that I couldn't feel.
Is this just how it is when there is a lot of debris around?
