LED Lighting - a more 'equipment' oriented thread
atompa
Michigan
All,
I'd like to start by saying that I'm not trying to make ANOTHER LED install post, I apologize if this morphes into such.
I'd like to focus more on the, WHAT, not how. The equipment, not a walk through.
1) LED lights- what 'quality' did you use? How many LEDs/Meter is 'enough'? eBay has great deals but I'm scared that they aren't intense enough.
2) did you solder or use waterproof quick connects after cutting?
3) switch install - what type of switch? Do you like where you mounted it? I may attempt to replace the factory JVC remote with a plate to house new switches. Either that or by the throttles.
4) did you use the jumper approach similar to the factory wiring?
Sorry guys, I guess it did morph into a how-to.... :/
I was looking into Cup holders and interior, holding off on underwater for now.
These are the cup holder rings I used:
http://www.ebay.com/itm/RGB-LED-Cup...upra-Malibu-/181401779438?hash=item2a3c637cee
Here is the RGB lights (they are super bright, so bright that I bought a dimmer switch because the dimmer function on the RGB controller didn't go dim enough):
http://www.amazon.com/SUPERNIGHT-50...&redirect=true&ref_=oh_aui_detailpage_o04_s00
Here is the dimmer switch:
http://www.amazon.com/SUPERNIGHT-Al...&redirect=true&ref_=oh_aui_detailpage_o03_s00
Here is the wire I used (soldered all the connections):
http://www.amazon.com/EvZ®-Color-Ex...&redirect=true&ref_=oh_aui_detailpage_o04_s00
This is the RGB controller I used:
http://www.ebay.com/itm/231611471261?_trksid=p2057872.m2749.l2648&ssPageName=STRK:MEBIDX:IT
No switch as that function is controlled by the remote.
Hope this helps!
Just stay away from this $hit:
http://www.amazon.com/Lerway-Contro...psc=1&redirect=true&ref_=od_aui_detailpages00
I bought two of these, thinking these are not very good quality, so I better have a spare :winkingthumbsup". Well, they f-ed up something in my LEDs so bad, took me several days of extra work of replacing fried/non-working parts and wire... I don't even know exactly what happened it was so weird :banghead:.
Wish I listened to smart people of this forum...
