Welcome to Jetboaters.net!
For those of you who changed your lighting what do you guys recommend. I'm assuming I can just change the bulb in the pool light? What options do I have for the bow? Thanks.
For mine the holes didn't quite line up, so yes I drilled 2 new holes. Super easy though, just put the base plate down, mark the holes with a pencil and drill. Use masking tape on the fiberglass to keep the gel coat from chipping.
I have a Samson tower on my SX 240 so I added a LED anchor light to the top of the tower that is sold through Samson. I discontinued the use of the pole light. But yes you could switch out that bulb with an LED version. I'm not sure what kind of bulb it is, so I bet you could take it out, then find the same bulb on Amazon or a local LED light store.
Also, the bulb in your OEM nav light is a festoon bulb. If you don't want to change the whole assembly you can just swap the festoon bulb with an LED version.
