Welcome to Jetboaters.net!
If the 190s use the same table set up as the 240s I think you will find that it's not the table but the mount that makes up the bulk of the total cost should you buy them from a third party. For instance, I can find many different shapes of tables online starting at $25 (mostly used) but the mount is close to $100 from Hamilton mfg. and over $100 from Yamaha sports plaza.
Will had been experimenting with mine to add a table so I actually have one with a mounting location in the cockpit and one on the swim platform. It sets up fairly well in the cockpit and seems really sturdy, but I don't trust the fiberglass on the swim platform to adequately hold up if someone were to fall across the table. One of my "to-dos" is to see if there is enough room to put a fairly large backing plate behind the fiberglass at the swim deck mount. I've got to take that area apart when I install my chart plotter so I should have an answer soon.
All that said, I never put it in place even in the cockpit on the water last year. For me, it may be one of those things that seem like a good idea but that I'll never really use. Maybe it should go live in Georgia...
