Maloney255XD
- 255XD
Hi,
I’m new to the forum, so please let me know if this isn’t the right place for this question.
I’m in the middle of upgrading the audio system on my 2024 Yamaha 255XD and am debating whether it’s worth replacing the factory cabin speaker wiring. My original plan was to use the JetBoat Solutions harness to integrate new amplifiers (Wet Sounds SDX2 for the tower and SDX6 for the cabin). Once I got into the project, I realized the factory speaker wire is 16 AWG. That discovery has me questioning whether I should upgrade to 12 AWG to better support the current amplifiers and provide some headroom for future speaker upgrades.
At the same time, I’m considering pulling 18 AWG RGB wiring alongside the speaker wire while everything is accessible. Since this is a DIY install, part of my hesitation is whether pulling heavier-gauge wire—along with RGB—will turn into a major headache once I get deeper into the hull and into tighter routing areas.
What I’m specifically looking for is real-world experience, not just spec sheets:
I appreciate any firsthand insight, lessons learned, or “wish I had done this differently” feedback.
Thanks in advance.
-Mike
- Did you notice any measurable or audible improvement after replacing factory speaker wire?
- Was the effort worth it once you factor in labor and routing through the hull?
- Any downsides to running heavier-gauge wire (stiffness, termination issues, fitment, etc.)?
- If you’ve done both tower and cabin rewires, did you treat them differently?
- If you chose not to replace the factory wiring, do you regret it—or was it the right call?
Thanks in advance.
-Mike
