Ottawa
- FSH Deluxe
I have a 2016 fsh190 1.8 liter naturally aspirated engine . Starts perfectly fine and seems to run great until engine warms up. I started noticing some hesitation in the engine power at mid to high range speed, I’d lose power and acceleration. I decided at this point with 50 hours on the engine to replace the plugs and do another water test and add some ISO to the fuel to remove any moisture that might have been in the fuel. After doing this I did another water test and it started up again after the engine warmed up 15 mins of operation high RPM’s . I was still convinced there might be water in the fuel and was told by the dealership using any fuel additives to remove moisture is harmful to the engine because it bonds to the water molecule and is removed during the combustion process , not goood for a high performance engine . So my next step was to pump out and removed all the fuel and put high test in and I did another water test . Still having same issue, hesitation and then complete loss of power. I decided to remove the plugs and notice number one was fowling up. Next step was to check electrical . I did an OHM reading on all coils and they all matched readings also did an OHM reading on the fuel injectors and they were reading same values. I decided to bring them in to the dealership to have them cleaned and tested Thinking number one could be dirty considering I had run out of fuel prior to all of these issues. Dealership said very unlikely and they were right after an expensive test but now I was able to rule them out . iv since done some Resistance checks on the wires leading to the injector and it looks good , I’m now at a loss . If anyone has any experience with this issue any advice would help. On a side note I’m thinking of changing the impeller and doing a ribbon delete , if you have done this with success or no performance gains I’d like to hear about it .
