Shane Ratliff
- Michigan
- NA
I bought a clean LS 2000 this year and it started acting up the last weekend we were on it. One motor is hard starting when cold but seems to run well once started. The 2nd motor starts fine but wont rev into the power band. Neither motor smokes much once warmed up. I had a compression test done, by a boat mechanic, and all 6 cylinders are 100-107psi with 2 different gauges and he is recommending rebuilds immediately. I am already in the process of having the carbs rebuilt and oil lines replaced with clamps. I was always told if all the cylinders psi are close and the motor seems to run ok to leave them alone. Do you guys think I need to have the motors tore down or replaced now? I was expecting to do the motors in the next year or two but I just bought the boat cash and don't have a lot of reserves left after committing to the carbs and oil lines. Thanks
