The.Queue
- LX
I have an LX210 that I picked up as a bit of a project, currently trying to figure out an issue with the port motor.
When I go to start the motor it'll get a revolution or two in before kicking the bendix out and disengaging the starter.
If I remove the plugs, it turns over just fine.
I swapped starters between engines, and the problem stayed with the port motor.
Unsure if this could be an issue with the bendix or perhaps just corroded cables.
