Max rpm with a Scarab 165…
Divouneh
165 ID
With my Scarab 165 (75 hrs today); I never keep full trottle (except when starting with a skier).
The max rpm for the engine (I have the 170hp) looks to be 8000rpm and full throttle will go further 🤔. Max speed will be around 42 mph …
Hi Luc : Speed is ok for me, punch to however I never stay to full gaz due to the over speed from my engine. My question was : do we have (probably) a max rpm we could go with my Rotax ?
We probably have an electronic protection 😚
Yes. Your engine capped. The max RPM depends on the engine's HP.
I think for most engines, the idle RPM is 1750.
The maximums:
150HP is 7300
200/250HP is 8000
These numbers are from the service manual. There's also a limiter at 7750 for 150HP and 8300 for 200/250HP.
I don't have the manuals for the latest 170 and 230HP engines, but if you can find them, it'll be posted in there or hopefully someone else can chime with those numbers.
I have the 8000 in mind, I will ask to my mechanic …
8000 rpm 🤨
I confirm, you have an electronic regulation, the engine tops at 8000rpm 🤩….
