MFI TRAILER BRAKES
06CCDMAX
McAlester, Oklahoma
SS
MFI trailer brake parts are dirt cheap right now on ROCKAUTO.COM just ordered new pads and one new caliper for $56 including shipping. all the brake pads for a 2000 Kia Sephia as well as the calipers are on warehouse closeout, my brake pads were $1.70. If your needing to do brake work on your trailer now is the time!
Seadeals
Greenville, South Carolina
Thanks! I’ll take a look.
Billtex2000
Lake Wallenpaupack, PA
Can you help out with the part numbers?
06CCDMAX
McAlester, Oklahoma
SS
2000 KIA SEPHIA 1.8L L4
AUTO 7​
1220022 (1220022:p)Caliper
Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty
$ 31.79​
$ 0.00​
1​
$ 31.79​
QUALITEE​
MF649Brake Pad
Wholesaler Closeout -- 30 Day Warranty
$ 1.71​
$ 0.00​
1​
$ 1.71​
Shipping​
Ground
$ 8.99​
Tax​
$ 3.27​
Order Total
$ 45.76
Visa​
-$ 45.76
Balance Due
$ 0.00
[TD] [/TD]
[TD]Part Number[/TD]
[TD]Part Type[/TD]
[TD]Price EA[/TD]
[TD]Core EA[/TD]
[TD]Quantity[/TD]
[TD]Total[/TD]​
i would not take this as gospel but from everything i have read and researched these look in appearance to be the correct ones.
Parts CatalogHelp PagesOrder Status & Returns
Parts
Catalog
Help
Pages
Wisefam22
Lake Lanier ga
Would the whole caliper from a 2000 Kia sephia 1.8 l4 fit? My wife tried to be nice and reduce work load for me by having trailer serviced. Guy said it would be a week before he would have part.
Wisefam22
Lake Lanier ga
Apparently someone replaced one of the bolts and it isnt stock so he wont touch it
dan144k
Palatine, IL
what year MFI trailer do these kia brakes fit?
I have a 2010 AR240. and thinking of inspecting and replacing the brakes. and trailer parts.
JetBoatPenguin
Lake James, NC
Did you ever get to a conclusion about the Kia brake set? As soon as the boat is splashed for the season and into the slip the trailer gets a refresh...
dan144k
Palatine, IL
No I have never done anything with my trailer brakes. They still work. Never found out about the kia parts
06CCDMAX
McAlester, Oklahoma
SS
I know my boat is a 2009 212 SS so I am assuming the trailer is the same.
06CCDMAX
McAlester, Oklahoma
SS
I know rockauto was having a closeout on those parts I ordered last year about a month back and you could rebuild your brakes completely for less than a Benjamin for both sides!
Hike
Montross, VA
I need to change Brakes/Rotors on my 2008 MFI trailer. I understand we can use 1997-2000 Kia Sephia parts but how about the rotors? I'm thinking these have to be a UFP part: Trailer Buddy Model DB-35 Disc Brake Hub/Rotor 9 3/4" ?
jmargo
Same. Looking for a spare hub for my 2010 MFI. Says model # is YMB240. Probably best to carry a rotor hub as worst case.
jmargo
Are there any issues with the Kia calipers attaching to the brake line ? You just separate it from the banjo block and screw it in directly ?
suke
Holly Springs, NC
The brake pads for the kia work fine. Neighbor just did it on his MFI today. Have to cut the "squealer" if it comes with it. He had to use semi metallic, it'll get him through the season and he can order the organic ones. I just replaced the whole braking system a little over a year ago, so I'm surprised the pads were toast. Checked the master cylinder and it functioned as it should. Figured worst case he could ride out those pads this season and we'll take it all apart in the fall and see what's up.
Cynthia
So the kia caliper worked and fit ok? I'm about to order and want to be sure. I have an '03 trailer.
Great info by the way, thanks.
