14SX190
- South Florida
- SX
So, in order to find out reason for contamination I went all out and glad I did.
Will feel confident I found problem on low compression on cyl#3 then #2 dropped.
Head is off to machinist to be re worked back to new for $250 plus parts.
Dealer was charging over 1k to take head off. Doubt they would of check block anode.
Have to get block water jackets clean next. Has crud stuck around cyl wall.
Need to find way to remove oil gear to replace TC while I'm at it.
Will keep updating as engine is reassembled
