JoeSpear
- Scarab
- HO Impulse
2016 Scarab 255 HO. Pesky misfire issue that I can’t seem to remedy. Faulting P0300 and P0301 on starboard engine…. Runs fairly good up until 5k rpm (still Misfiring but not really impactful to performance) beyond 5k rpm it misfires significantly and cant keep the rpm timed up with port side motor. If I hammer down, the rpm sometimes pops up and down dramatically. I’ve done the following with no remedy…
- new plugs. Not fixed. Even swapped plugs with port side, still misfiring.
- swapped coils with port side, no change.
- removed and cleaned injectors, not fixed.
- swapped injectors with port engine, still not working.
- replaced 02 sensors, not fixed.
Planning next…. Swapping Ecu with port engine, swapping wiring harness with port engine, testing compression….
Anyone have any ideas??? Thanks in advance! FYI… anyone want to buy a scarab? Smh!
