Jgorm
- San Diego / Colorado river
I'm working on better understanding on the oil tank off my non ho mr1. I have oil water contamination and low compression. Part of my investigation has taken my to places where oil and water are in close connect. It's an impressive casting that was well thought out!
The side plates hold the cooling water and route it through channels around the central oil tank. There are 3 port of the cooling water, 2 on the bottom and one at the thermostat. They all connect to different areas on the cooling jacket. I haven't figured out the flow direction because it doesn't really matter for me now.
I haven't figured out the oil flow yet. It seems to return into the top side of the tank through a complicated baffle system to return oil to the center of the tank. The center vent on the top seems to be a vent similar to the pcv on a car. There are two holes on the bottom that attach to the engine block. The one on the right goes into the stand pipe channel on the side of the oil tank. I really can't explain that. Anybody have any insight?
The good news is that I pressured tested the cooling side and it holds 20psi, and that the meal is in excellent condition. Does anyone know what the operational pressure is for the cooling system?
Here are some pictures. It would be fairly easy to pressure test it in the boat if you think you might have a problem. Hope this helps someone.
