Navigation Lights Malfunction
Ar240bill
2019 AR 240 with ~55hrs
Hey everyone,
Coming in last night I notice my nav bow lights would not come on. On the CONNEXT system at the bottom of any screen, I click on “navigation” and it automatically switches over to “anchor”. The anchor light on the tower become illuminated and the bow lights will not go on.
When I go into the lighting page on CONNEXT it will allow me to select “navigation” but only the anchor light will illuminate. It also will not indicate on the lighting schematic that the bow lights are on.
The interior LEDs are functioning properly.
I have not found anything else on the boat to be out of sorts.
Anyone have any idea?
Thanks!
Merlion
Miami
Check the circuit breakers, there could be a blown fuse.
marcham
Comox, BC
AR195
Hello and welcome to the forum!
Did you check the bulb? Do you have a multimeter to check for voltage at the light fixture?
marcham
Comox, BC
AR195
Easy fix, those are the best!
Ctheodores
Mine is doing the same thing. Is the bulb easy to get to ? I will have to check to see if mine came loose
Rei_210
Where is the fuse? My lights are not working but switch panel is.
sunbyrned
Louisville, KY
It could also be loose wiring. After putting my anchor away the other night, the lights didn’t work. I checked to see if I snagged any of the wiring while putting the anchor away. Luckily that’s what it was and it was an easy fix.
