kglass33
- Limited S
Hello,
I have a 2012 Yamaha 242s Limited. One of the engines won't start. It will turn over but wont fire up. I did replace the plugs in both engines. We took it out Sunday, our second time out this year as we live in Michigan. Both times I started it this year they fired right up. On Sunday we drove it around a few hours then anchored out to enjoy the weather. When I set out the anchor I put it in reverse to help set the anchor. I stupidly shut off the boat and left both throttles in reverse. When attempting to leave I tried to start it in reverse (not sure if this is a bad thing) realized what I had done I put them in neutral to start them and one engine will only fire up now. I have cleaned both ports out and made sure they are locked. I purchased a fire indicator to make sure it is getting spark(trying it tomorrow). We keep it at a marina but they aren't able to get to it for a couple of weeks. Hoping for some other trial and error ideas. I have seen problems with lanyard switches but mine only has 1.
