NewBoater
- Virginia Beach
- 242X E-Series
As my name suggests I'm still new to all this boating stuff and still figuring things out as I go as this is our first boat we've owned.
At our house we have a pier and the 2 wood pylons at the end of the pier. Last year I just tied the boat to those 2 pylons and it worked out well enough for the year.
We have 2 more wood pylons a little further out in the water about 20 feet away where the last owner used to tie his boat to all 4 and the boat would float in the middle at all times rather than against the pier like I did it last year. Granted I have white protectors on the wood that are about 10 feet down the pylon and also used bumpers so no damage occurred at my pier.
Seems smart to figure out how to use all 4 for this year to keep the boat floating in middle and not rubbing against dock pylons (even though they have cushion protectors and I put bumpers down also).
If you wouldn't mind explaining to me the smartest knot to use for the 4 around the pylons and also in what order to do them. I'm guessing 2 farthest out in water first and use enough slack to be able to push back to pier but then where to go from there on tightness of the other 2, etc.
I might should get cleats for the pier and pylons instead of using the wood and wrapping it around (damaging wood)?
We use boatel mostly but have it home on weekends so this is for how I will tie it up on weekends.
Sorry for the newbie questions but any helps appreciated!
Maybe someone would even be willing to draw a little diagram for me of the steps and order to go in.
Thanks!
Thanks!
