Welcome to Jetboaters.net!
Does Anyone know how to take the coupler apart and fix the wire inside of it or should I just cut the wire and ground it to the motor or maybe they have a replacement coupler ???
Take a picture of the coupler..................it will take some searching but that coupler is out their somewhere hear is an example of a quick search.
It might be a 2 pin r 4 ect............
If it is the same one as on my 06 the flat end comes off. You have to release the locking pins on the sides and pry it off with a small screwdriver. The cover is a jumper for all the wires going into the connector.
I had the same problem with my fuel pump not running and it was that junction that was the issue. I sprayed electrical contact cleaner on and put dialectic grease on the terminals.
