SprockJohnson
- Tampa, FL
Hi all,
New to this forum but not new to jet boating. I have a 2006 Yamaha AR210 I bought new in 2006 and although I haven't had many problems over the years this one is turning out to not be simple to diagnose. I last ran the boat a week and a half ago and it ran great and had a thorough post run rinse out from the saltwater. Yesterday I went to put the boat in the water and the starboard engine would not start. The starter was turning the engine over, although slower than the port side, but it would not start. Here is what I have already done to troubleshoot-
1. The tank is full of new ethanol free fuel
2. The shifter/ throttle is in neutral and I have also swapped the connectors for the neutral switches back and forth between the two sides.
3. The kill switch has the lanyard attached and I have swapped the connectors back and forth between the two engine sides.
4. The cleanout hatch switches had already been bypasses a year ago but I inspected the connectors and splices to verify there is no corrosion.
5. All spark plugs were removed, inspected, and checked for spark and they all appear fine. They were just replaced a couple months ago and only have a few hours on them.
6. All battery terminals and cables for both batteries (one was added aftermarket) and the aftermarket battery selector switch were checked, removed, brushed with a wire brush, and reattached to the batteries and switch.
7. Swapped the connectors for the ignition switches to see if the other switch would start the engines. Port side still starts but same problem persists with the starboard side.
8. Both batteries are fully charged, voltages were checked and reading 12.6-12.5v.
9. Removed deck hatch and removed starboard side fuel pump unit, checked fuel filter screen which was clear, and re-installed. Fuel line was pressurized before removing and pressurized again after installation.
10. fuel is observed misting out of head when spark plugs removed.
11. Throttle body checked and servo functioning.
12. Attempted to start with starting fluid but no detonation.
13. Checked all fuses on starboard ignition module.
14. Checked voltage at positive starter cable and it read approximately 10.6v and engine rpm while cranking was somewhere between 350-400rpm.
Anybody have any ideas? I'm thinking my next step will be to swap the starters to see if that is the problem.
