2kwik4u
- Buffalo, NY
The axle can be on top or below that leaf. Load doesn't really matter.If I buy this leaf spring
and this hanger kit
The problem is the shackle link would lower the attachment point of the leaf spring. For example, on the picture below, these 2 dimensions need to be equivalent. Therefore I would need to replace the front hanger to a longer hanger. And raises the trailer roughly 3-1/8" (the length of the shackle link). I think at that point, I would have to move the axle to above the leaf spring to maintain factory geometry.
The only geometry you need to maintain is a level frame assembly.....just move the ball on your truck up a bit and you should be good.
